woodydog
- Mar 27, 2008
- Verona, WI & Lake Tomahawk, WI
- 2015 Polaris Rush Axys Pro S 800 60th Anniversary
2015 Yamaha SR Viper RTX DX
1983 Yamaha Vmax 540
1981 Yamaha SRX 440
I have read on here that pulling your tunnel protectors out will help stop the heavy ice build up in the tunnel. You guys aren't doing that with studded tracks right? I'm going with 1.38 inch long studs, 96 total.
Thanks,
mjd
Thanks,
mjd
NyTrOMaNIaC
If you're running studs, I'd keep them put, especially up by the drivers. Mine, on the other hand, are gone in the front, and the rest are goin this weekend.
woodydog
- Mar 27, 2008
1981 Yamaha SRX 440
Do you have studs?
Gibby
- Jan 28, 2005
- Jackson, Michigan
- www.fitzgibbonstruck.com
i am pretty sure if you run studs you need to leave the tunnel protectors on
NyTrOMaNIaC
woodydog said:Do you have studs?
Nope, 1.5" Intense track here. Studs will do me no good where I want to go.
Nytro'd40th
I wouldn't recommend running with out the tunnel protectors. I just pick the back of my sled up and slam it to the ground whenever I feel its necesary. It seems to work good enough for me and I'm sorta fussy about my machine.
woodydog
- Mar 27, 2008
1981 Yamaha SRX 440
No problem, I didn't plan on pulling them with studding. Just wondered if that's what some people were doing ?
Thanks!
mjd
Thanks!
mjd
NyTrOMaNIaC
Just a heads-up for anyone plannig on doing this ; If you're doing a track change and need to remove the front tunnel protectors up by the heat exchanger to fit a taller lug, take advantage of the available work space now and remove the rest along the tunnel at this time, save you from having to remove the skid or gas tank later on like some folks on here...
Also, the Tech Advisors and fellow TY members will Thank you for it as well...lol !
Thanks Turk and NLVMAX
Also, the Tech Advisors and fellow TY members will Thank you for it as well...lol !Thanks Turk and NLVMAX
Newfiebullet
Do not run your sled without tunnel protectors if you have studs. You'd be amazed what carbide studs will do to an aluminum tunnel, in no time at all.
Alatalo
- Jan 11, 2005
You will also be amazed how far up the tunnel the track will actually reach (during braking). With correct track tension as well as overly tight track tension...
NyTrOMaNIaC
UPDATE...Don't bother trying to remove these by lifting the gas tank, it's of no use, heat shields and exhaust headers are in the way. Only way to get at the front tunnel protector mounts is from underneath. Drop the skid with the drivers still in tact, and after you've removed the rear and mid rivets, just get under the sled with the rear elevated, pull down on these rails slightly until you can get a chisel or some kind of flat sharp object in between the rails and the tunnel, and smash away with the hammer
There's 3 rivets holding on the front part of these, so make sure you get em all before trying to remove the protectors. A few good hits with a chisel and hammer and they're gonzo !
Egon
- Sep 28, 2007
- Dalarna, Sweden
- www.t.kth.se
To late, removed the gas tank yesterday
Alatalo
- Jan 11, 2005
Egon said:To late, removed the gas tank yesterday![]()
If you have done that much, just continue with the exhaust heat shields and the header pipes. Not too difficult...
