Tyloooor
anyone have a measurement for the spacers??? I've seem to have misplaced mine.....
do I really need them?
herndonp
contact Zbroz and they should be able to help you. http://www.zbrozracing.com/contacts
Tyloooor
i did and their only a $1.50....it would cost more to ship them....just looking for something i can pick up locally
herndonp
Couldn't Zbroz give you the dimensions so you could look at your local hardware store.
edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
I'll check the measurements on mine tonight if I get home early enough, if not tomorrow at the latest for you. Right off hand I think there about 3/8 to a 1/2 inch at most.
Tyloooor
Thanks!
edge_232
- Jan 15, 2014
- Madison WI
The spacer thickness is 3/8" and typically go to the rear of the upper mount to give you a little bit of chamber. Or they can be places on the front side to eliminate some of the chamber.
Hope this helps.
Hope this helps.
Tyloooor
thanks.....going to pick up some washers today
edge_232
- Jan 15, 2014
- Madison WI
