stomper
I also have a thread going on this in the aftermarket suspension section. Sorry for double posting but I am desperate for help on this issue. Has anyone installed a zx2 skid into a 03 rx1 or any rx1 for that matter. They are all the same. I am in the process of doing it now and I have a serious issue. It's an 03 rx1, 136" x 1.75" lug track with 7.125" drivers, 2.58 pitch. All measured out with the correct measurements the rear mounting hole for the skid lands on the bend where the tunnel meets the foot board. The verticle drop measurements for the rear mount is measured from the lowest clearence point in the tunnel. This is to make clearance for the exhaust and tunnel protectors. The only way I can see to make the room I need is to go to a smaller lug track and I don't want to do that. Other option would be to remove the tunnel protectors but that would only give me 3/4" which is borderline enough and thats with the minimum clearance of 1/4" to the exhaust. The rx1 tunnel is the same as the apex so someone must have run into this problem before. I have tried to contact AD Boivin for a solution but I can't get anyone there to pick up the phone. Any help would be appreciated.
