stomper
Does anyone have the dimenssions for the tunnel mounting plates for a ZX2 suspenssion for a 03 RX1. I checked with AD Boivin and it will be over $300 by the time it gets to me. Thats a bit steep for a few plates , some rivets and a few bolts. I have a cad program that I can create a dxf file and get them laser cut for next to nothing, as well as an assortment of multigrip rivets left over from the bulkhead replacement on my wifes attack. I would be gratefull. I would be willing to trade a set for the use of the measurements.
_________________
_________________
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Search under my name and find the universal instructions for mounting the skid and then you can just make your own plate. The plates are expensive, but they are slick to install and have it dead nuts. Do the universal and just make your own plate from that measure 15 times drill once...
stomper
Whats the difference between the unversal plates and the ones designed spesifcly for the RX1
kinger
- Jan 17, 2005
- Clear Lake, IA
The specific plates have a hole in the stock suspension location so you put a bolt in there that locates the plate perfectly then you drill the holes for the ZX2.
stomper
Ah, ok. Maybe it would be better instead of doing all the measurement stuff. I didn't know it would be that easy with the specific mount kits. Thanks
kinger
- Jan 17, 2005
- Clear Lake, IA
Yes they are slick. Found the unversal ones if you want to mount yourself
http://www.ty4stroke.com/viewtopic.php? ... =universal
stomper
Just curious about the RX1 specific instalation kits for the ZX2. In the universal kit instructions, the mountng holes positions are determined buy the track lug height and drive sprocket diamiter, as well as other factors. Would this not be a factor with the RX1 specific kit also. If so are provisions made in the kit to factor in this.
kinger
- Jan 17, 2005
- Clear Lake, IA
They are set up for the track that came with the sled stock is my understanding.
stomper
OK, thanks, so I may as well just get the universal instalation kit because I have a 2" lug track
