DC5
I have 1500km on the Hi-torque rollers and so far they all look good.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
If I recall, the Hi Torque are made in Canada out west somewhere?I have 1500km on the Hi-torque rollers and so far they all look good.
Wondering where you got yours from? Pricing?
thanks
Dan
DC5
He is out in B.C. They are $85cdn for 3 or $69 if your order more than one set. You can order them online from his website.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
thanks I just found it online too...He is out in B.C. They are $85cdn for 3 or $69 if your order more than one set. You can order them online from his website.
It is a nice alternative for CA buyers, the exchange rate up here is taking a dump more and more.
Dan
Kevin
Anyone in Ottawa need a set?
The deal for two sets is great
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
LOL, I was thinking same....I told Tom and he said, Dan you know you will have a SW soon enough! lolAnyone in Ottawa need a set?
Dan
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
i wonder if heat causes it after the sled is stopped? seems they would have to get pretty hot. or excess torsion? these are too new to be dirt binding them for everyone. i have a microscope at work that i may be able to use to get pics of my stock ones, and the cat ones i replaced. i can see damage starting at 45 miles on cats with magnifier glass. have to get good look at ulmers with 185 miles on them.......
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
850 miles on my cat rollers now and they look like new. I am not easy on my machine either.i wonder if heat causes it after the sled is stopped? seems they would have to get pretty hot. or excess torsion? these are too new to be dirt binding them for everyone. i have a microscope at work that i may be able to use to get pics of my stock ones, and the cat ones i replaced. i can see damage starting at 45 miles on cats with magnifier glass. have to get good look at ulmers with 185 miles on them.......
Sent from my SM-G920W8 using Tapatalk
- Dec 6, 2016
- saegertown pa
my cats look ok to the naked eye, but with a magnifier you can see what appears to be melt starting. originals were flat.850 miles on my cat rollers now and they look like new. I am not easy on my machine either.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
that would be a solid theory, but Im not sure cause the clutches on these seem to run very cool to warm at best...nowhere near what I would call hot. Like my doo.i wonder if heat causes it after the sled is stopped? seems they would have to get pretty hot. or excess torsion? these are too new to be dirt binding them for everyone. i have a microscope at work that i may be able to use to get pics of my stock ones, and the cat ones i replaced. i can see damage starting at 45 miles on cats with magnifier glass. have to get good look at ulmers with 185 miles on them.......
They seem to be very light on material, meaning I could sand out the flat spot so easily with emery only...Its not like the material other rollers ive messed with are made from.
I would guess yammie replacements when they come, will be diff material for sure.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
Guys how's this theory? Take your spring out of your helix and then put your helix back on the sheave , then spread your sheave out and back in, watch how your roller responds to the ramp, the roller gets forced outward or inward depending on on what direction the sheave and helix are moving, the roller doesn't run parallel to the ramp, they seem to drag slightly sideways. Could the side pressure of the roller be binding on the sheave housing not letting the roller spin freely on the ramp?
roweboat70
- Jan 25, 2011
- 2017 Yamaha Sidewinder STX-DX
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Figures. I just ordered Thunder rollers and received them today.View attachment 126032 View attachment 126032 Yamaha replacement rollers should be at your dealer now. Picked mine up today. Leaving the Ulmer rollers in and will keep these for spares.
PowderFalcon
Pinnin' it!
I did the same PLUS grabbed cat rollers while waiting for thunder rollers to arrive! Guess I've got 3 sets :S
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
No #*$&@...same here, got Hi Torque rollers coming. Now Yammie comes with a fix? GRRR
Can you snap off a few more pics different angles? Hard to tell what type of design these are.
Dan
Dan
