03 grizzly duz not like water
600_srx_man
hey iam working on a friends 03 grizzly and it will hit the rev limiter when it goes in to the water, it duz not matter if its in 4x4,2x4,highor low it will not let the engine rev out, i have put dielectric grease on the diff plugs and it seemed to work for about 2min then it happens all over agian, your help would be greatly Appreciated since he is goin on a trip this friday
I think the problem is when you hit the water the steam from the engine goes up and tries to escape but there is no where for it to go i have the same problem with my 450 Grizzly the place where the steam goes is into the air intake tube under the gas tank and it chokes the engine out when you give it gas(RIGHT???) you should try to remove the seat and go through some water and see if it clears it up, it lets the steam escape.
Steam, enter the water at a slower pace .... I have had mine in to just under the fenders and runs perfect but if I hit the water fast it steams and chokes of the air intake under the tank cover...
Try putting your airhorn(factory snorkle) between your gas tank cover and your seat and see what happens, just don't forget it's there when it is time to wash! Also consider Twin-Air filter or UNI plus a power tip, the 2 allow a lot more air in and out which in turn dilutes the steam and lessens or completely eliminates the steam issue. Good luck.............Irv
