03 RX-1 Clutch
Chesterfield, MI
I have looked around here and am looking for some info. I am looking to do a full rebuild of both my clutches. I have 6000 miles on them and they are pure stock. Now the only thing I can find is clutch kits, does someone make a clutch kit that would just be stock, and do you think it would cost as much as a full clutch kit. I have not taken the clutches apart to see if there is anything wrong, but I am doing a bunch of long over due stuff, full bushing kits front and rear, new seat, risers for handle bars, and I don't want forge the clutches.
The best thing is to buy OME parts for the clutch yamaha does make a rebuild kit for the primary clutch for the secondary you only need to bushings and the 3clutch buttons an you are good to go.
clean them good Hot water with dawn dish soap. Check the bushing for wear, the buttons will need to be replaced, new springs, check the helix if the buttons are bad. The rest should be good.
This will help
With the white secondary spring set it at 70 degrees twist when you install.
The warrior and the rx1 mountain both use the white secondary spring as stock. The stock white secondary spring settings for the warrior is 60 degrees and the rx1 mountain 70 degrees.
