03 RX 1 DEAD AFTER CARB CLEANING HELP! FIRST TRIP TOMMOROW!!
jdp1under
CT, NO SNOWVILLE
2010 RS VECTOR GT LTX STOCK FOR NOW!
HEY GUYS IM SCREWED HERE I CLEAND THE CARBS THIS MORNING AND PUT EVERYTHING BACK TOGETHER AND NOW THE SLED IS DEAD. CHECK THE BATTERY IT HAS 12.37 VOLTS READING. WHEN I TURN THE KEY ABSOLUTLY NOTHING HAPPENS!!!!!!!!!!!!! PLEASE HELP I TRIPPLED CHECKED ALL CONNECTIONS OF TPS AND ANY OTHER PLUGS I PULLED TO GET IT OUT.
IF ANYONE KNOWS WHAT IT SCREWED UP HERE PLEASE POST OR CALL ME 203-668-8579 CELL AND COMPUTER ARE HERE IN THE SHOP!
THANKS JDP
JUST CHECK THE ONES RIGHT SIDE BY COOLANT BOTTLE IN LITTLE BOX AND ALL FINE ALSO CHECK THE 2 THIRTY AMP FUSES BY BATTERY ANY OTHERS?
Did you have the tank cover off for any reason? If so, check the key switch plug...is the kill switch off?? Are the battery connections good? Good grounds?
When you say nothing...you mean no clicks no nothing? Maybe you've got a bad solinoid or starter relay...
Did you put the TORS back or did put the wornge wires Somewhere. I say take it back apart and you may find somethng.
I HAVE BEEN CHECKING AND RE CHECKING ALL WIREING IM LOST WOULD TORS SHUT THE MACHING COMPLETLY?
GOT IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! PLUG MUST HAVE GOT KNOCKED LOOSE WITH AIR BOX THANKS FOR ALL THE QUICK REPLIES AND THATS WHAT SEPERATES THIS SITE FROM THE REST!!!!!!!!!!!!
Usually the Kill Switch gets bumped down. But, maybe you did something to the main fuse. The main fuse is by the Battery right next to the start relay. Did the start relay get bumped around?
Do you have power to the Signal Fuse, with the Key On?
Attached Fuse Section of Tech Manual.
I did that one time hit the kill switch and couldn't get it to go call the shop they came out to get and all he did was walk up to it and say did you check this.
LaLaLa LaLaLa LaLaLa Thats some funny sh!t right there!
No, I looked like an #*$&@. Now I check it all the time don't want to do that again.lmao
Yeah man I got to agree that's some real funny
sh!t hahaha. My cousin was drivin his dad's old poo widetrack with the fuel shut off switch and he hit it somehow, half hour trying to get her started before he noticed it. My buddies went and put this girl's parking brake on her old poo onetime and when she tried to move it would just crawl and she got right upset thinking she broke her dad's old poo hahaha.
