03 rx-1 ohlins
super1c
Moderator
Freeland - Otsego lake, MI
22 sidewinder LTX-LE
Hi guys,
Im looking for some specs on the 03 rx-1 ohlins Ya 352. I need to know the min and max preload spring lengths and how it is measured, Is it spring length or eye to top of spring. Also what is standard for number of clicks. Its a 15 click reservoir. Thanks chris
don't think there was an ohlins on the 03 RX-1 kayaba non -rebuildable in rear junk from day one. Prob someone changed it.
i do not have the specs but a viper one might be close.
I'm having trouble dialing in the rear suspension with the new ohlins in it. Im using BTV's post and am getting closer but i thought if i had the stock specs might help me out a tad. Thanks guys. chris
Ohlins specs 19mm of preload on the YA352. The spring has 175mm of stroke before coil bind. The shock has a stroke 158mm, all of that stroke is not used on the sled, which is why the preload is slightly more.
I have the same on my 03, but i've stretched it into a m10 warrior. I have NO preload on my front springs. Raise the front end off the ground and just tighten the locknut down to the top of spring. You should be able to move the spring by hand, but not loose. I have my clickers on the lowest setting with a 12mm swaybar and a pioneer wide front end kit. I dont know if this helps, but I tried.
