03 RX-1 updates/recalls
LazyBastard said:
No recalls. Several updates for improved durability/performance. The control rod upper loops were weak - updated for 04 - thicker and stronger. Hood bumpers to keep the hood from rubbing on bolt heads. Rivet update to keep rivet head from rubbing on seat. Swaybar links - longer for flatter cornering, but its better to replace bar and links to 04+ and even better to replace bar with 13mm aftermarket bar. The other most note worthy update, which everybody did aftermarket was FRONT SPRINGS - 03 had progressive springs. Get #140 straight-rate springs.
Control Rod upper loops? Please expand
LazyBastard said:
Thats really not accurate. "100 improvements" included things like HOOD STICKERS and moving that rivet down 2mm.
Whether that statement is "Accurate" or "Inaccurate", it was a sales pitch nonetheless.
The whole sled ('03 & '04) should have been a recall. Some guys paid for them twice to straighten them out. :o|
Lets not forget about that freekin rear suspension that got upgraded in 05. It dont matter though, W arms still break like tooth-pics!
1. My 03 does not burn a drop of oil!
2. Yes, there are a lot of mods you can do to make it better, but they are not necessary to have a good sled that will last many years.
Indy is right. You can do allot of mods to the RX-1 to make it better but you can do that to any sled. I did the rivets to the seat and the rubber bumpers to the hood. I did make adjustments to stock suspension and put Woody dooly 6" on the ski's. Does not rail like the Apex but it is still a very nice responsive fast sled. If I had the coin I would be riding an Apex but until then the RX-1 is great without having to invest allot of money.
I did expand. THICKER AND STRONGER.
BURMAD69 said:
Most all of the 03's burn some oil,If someone is telling you otherwise they arent being exactly truthful. But you havr to remember loose is fast.
My 03 doesnt burn a drop...period..
:die ============ :jump: ----------------------------------- LaLaLa ..................... ;)!
