not near my sled now and trying to buy battery, who knows exact dimensions of battery ?
on yuasa website dimensions are listed as follows
Battery Type: YTX20L-BS
Voltage: 12
Capacity: 18
Dimensions: 6.875" x 3.4375" x 6.125"
Weight: 11.2 lbs.
Metric Dimensions: 175mm x 87mm x 155mm
Metric Weight: 5.1 kg
Polarity:
Acid Volume: 0.93
Amps: 1.8
C.C.A.: 270
however when searched on amazon (i have prime) i see under more info on this item - http://www.amazon.com/Yuasa-Maintenance ... uctDetails
dimensions are listed as Product Dimensions 9.1 x 7.8 x 5.7 inches ....
also there is alternative "Chrome Battery" brand, not sure about it and this website http://www.rakuten.com/pr/product.aspx? ... =265783914
thank you !
Voltage: 12
Capacity: 18
Weight: 11.2 lbs.
Polarity:
Acid Volume: 0.93
Amps: 1.8
C.C.A.: 270
thank you !
Nothing wrong with the OEM battery in my book look after them and they last a long time. At the top of every page there is a Yamaha Parts Finder link if you use it you find your parts.
This is the part number I got from using that link.
YTX-20LBS-00-00
YTX20LBS YUASA BATT | YUASA
113.99 1 113.99
YTX-20LBS-00-00
113.99 1 113.99
