05 Rs Venture starter/battery issue
Damn I just realize I probably spun my motor backwards trying to remove cam bolt urgh!!!! Now Im into timing issues, checked the tensioner and it has orange dot I think thats the one that needs to be updated. Could I have damage valve turning it backwards? I turned it maybe a quarter turn.
Remove the bolt with an impact. If you don't have one you can hold the primary clutch and use a breaker bar and socket to turn the bolt. Make sure you don't rotate the engine in the reverse direction while working on it.
I think I did rotat it backwards maybe a quarter turn
