ogre
My 05 RX1 is using a little oil not much. Is this normal?
ogre said:My 05 RX1 is using a little oil not much. Is this normal?
that's exactly the right way to check the oilapltx08 said:Make sure when checking your oil that sled was atleast ridden for 15min, I always check mine after every ride this way its good and hot, I let it sit for 2 or 3 min and check it...your readings will vary a lot depending on how you check it, always do it the same way to get an accurate reading.
200ml in 335kms sound like a lot to me...those your sled stay out in the cold when not in use, if so check your CRANKCASE breather hose in your airbox to see if its FROZEN up, they tend to freeze up and clog with ice and this creates back pressure in your motor and will get it to use or leak oil on the PTO/CLUTCH seal.
