visegrip
what are the realities of this sled? 195hp 225 with high boost correct
will it outrun a 2005 mach z with twin pipes in 1000ft? on snow.
top speed of this thing 2000 ft on snow? will the carbs pop off like i have seen on some? just looking for real world info thanks.
Buckeye
- Lakes Region, NH
Boost is adjustable. Yes it should beat a MachZ, if you set up the suspension and traction properly. Top speed in 2000 feet should be in excess of 135 mph. The carbs usually don't blow off. The intercooler is more likely to blow off the carbs if it is not fastened properly.
