LazyBastard
Convert said:LB do you run 6 inch carbides on both sides or a 4 on the inside? I've seen a few posts with that setup saves 10% when it's time for new ones![]()
I just gound the stock POS 120 deg 4" off, trying to get some new ones now. I'll be going 6" all around... not completely sure, but that much carbide might make crazy for 121" track. I do have the rubber to support it.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
So you recommend 4" both sides for a 121?
LazyBastard
I really can't recommend anything since I don't have the experience with it. Since I usually go overboard on EVERYTHING, I would probably get 6" all around regardless of the track... to hell with the crazy :twisted:
jimmie d
The problem is the inners wear much faster than the outers so 6" all around will allow you to switch the outers to the inner when the inners wear. Can't believe I just wrote this.
Jim
Jim
