You will get better heat with the 07 bars and Yamaheater combo. Those aluminum hooks suck a lot of heat from the 06 bars. They are a lot better if they have been upgraded to the plastic ones. The biggest gain is that you will have a larger area of the grips heated.what is the difference between the 06 and 07 attak handle bars? I have an 06 with Yamaha heaters If I put 07 bars on with the Yamaha heaters will they work better?
I filled my 06 bars with spray foam , helped out . They also have a product now Bar Buzzkill that helps with vibrations also. I like the look of the 06 grips too ,that’s why I stuck with themYou will get better heat with the 07 bars and Yamaheater combo. Those aluminum hooks suck a lot of heat from the 06 bars. They are a lot better if they have been upgraded to the plastic ones. The biggest gain is that you will have a larger area of the grips heated.
