Big lad
- Jan 18, 2021
- Ottawa
- 06 apex
06 sno pro sx f7 swapped
03 f7 Canadian edition
G’day lads,
I’m new to the Yamaha family I picked up an 06 apex for a screaming deal but I’m starting to see why it was so cheap. I had code set 84 and 42 come up on the cluster and a constant flashing yellow light. I bypassed the tors to eliminate that for now during diag, checked the pickup for the speed sensor and cleaned the ribs to ensure proper signal all ok there. Checked speed sensor found broken wire insulation at the sensor where it bends figured some corrosion worked it’s way down the line into the sensor causing no pick up. Installed new Yamaha sensor and still no speedo, disconnected battery over night and tried running on stand for about a minute straight still nothing. When sled warms up it’ll stall but when cold it’ll idle. Checked cluster to see code set and found 11,15,22,30,81,84 but no 42. I’ve seen guys say that there’s relays that may go bad or ecu I don’t have err 01 which I’ve heard means ecu has left the party. Any help would be appreciated
Big lad
- Jan 18, 2021
- Ottawa
- 06 apex
Also does anyone have a link for the workshop/wiring diagrams?
2010 Apex fails to start | TY4stroke: Snowmobile Forum | Yamaha - 4 Stroke
Read the linked thread.
Become a VIP and get access to service manuals and wiring diagrams.
become a site vip and i can send you a copy of the service manual.
Big lad
- Jan 18, 2021
- Ottawa
- 06 apex
I paid to be vip but that was within the past hour is it an immediate thing?
mrsled needs to activate you 1st and then i can get you the manual.
Big lad
- Jan 18, 2021
- Ottawa
- 06 apex
Mrsled got me the manual hopefully I can get er figured out!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Check over for corroded ground blocks and mice chewed wiring.
Big lad
- Jan 18, 2021
- Ottawa
- 06 apex
Ya I stumbled onto the ground blocks last night when doing some more research, I’ll check in the next couple days appreciate the feed back
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
BTW, welcome to the best damn website on the internet. You will find a lot of information and very knowledgeable people on here. Also IMHO the best NA factory sled out there.G’day lads,
