APEX162
- Dec 17, 2020
- Utah
- 2006 Apex mountain 162
Hi guys, first time posting. I just picked up a used 2006 apex with 1700 miles and a 162" track. It still has the stock junk maverick track and its missing some lugs and folded over pretty bad. I was thinking a camso challenger extreme 162x2.5lug 3 pitch and I can get either a 15 or 16 wide. Sledtrack.com has them for 850 shipped to my door. Power claw was over 1000 bucks without shipping. Would you guys stay with the 16 wide or go to the 15. Im thinking if I did 15 wide the lug is .25 taller on the extreme than the maverick but clutching might be close.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Wish I could help you but I've got no experience in those track setups. Someone will chime in.
BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
I went 16" needs all the help she can get if you ride in any deep snow. Single biggest improvement I did to sled and that was with the clutching stock at the time.
Maverick is probably the worse mountain track ever made...
APEX162
- Dec 17, 2020
- Utah
What did you do for clutching K410?
BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
All I did was add weight to primary with the heavy hitters. Told Terry there my set up and he sent them to me ready to go, I haven't played with them since. Sled really hauls with stock 20/40 gearing and other mods. Adjustable primary weights are probably easiest and best bang for your buck as far as playing with your clutching.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have a good take off Challenger Extreme 2.5" 162 x 16 track off a Apex Mountain if you're interested?
$700 shipped, I can get pictures if you like.
APEX162
- Dec 17, 2020
- Utah
My new challenger extreme is actually sitting under my sled right now. Just waiting on a new jack shaft bearing to show up. Im going to have to check out these clutching weights. I read some guys were having to trim the front cooler on the bulk head to get the 2.5 lug to fit. Is it just the two raised sections that poke out farther than the cooler fins?
Airzemee
- Jan 13, 2022
- Saskatchewan
- 06 APEX MTN
A year late but do you still have this track by chance?I have a good take off Challenger Extreme 2.5" 162 x 16 track off a Apex Mountain if you're interested?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes, still availableA year late but do you still have this track by chance?
