06 attak no-start
northernguy10
Sudbury,ont.Canada
went throught my fall ritual check the sled from one to the other. battery tender on the battery turn the key nothing but click,click,click . now disappointed take battery charger to start(yes tender was removed) machine turn over great, but no start. put new plugs in while battery was charging . try to start the sled you can hear the fuel pump (watch the lights in the dash) turn key machine turn great ,but no start. am i missing something ? search for potential gremlins on site ,on sled nothing. #$%&*
check all connections also check fuses around the battery and over the chain case fuse are good . with the charger on it it turn over fast just don't start .
i had a click click sound. after several different things it was found to be the starter solenoid. i tried charging ther battery and then a new one. check all kinds of cables. they do burn out just not all at once. once my sled was warm no problem but once it sat over night i could not get it started without a charge. eventually the charge did not work anymore and it just continued to click click. its located to the left of your battery and should be green.
but when I put a battery charger on it the motor turn over great (to me) . it just don't start . i turn the key listen for the fuel pump the light on the cluster usually goes out at the same time than crank . but it doesn't start!
