DEERSNIPER
I have an 06 Apex that won't start. I have had it on a trickle charger most of the year and the charger says "charged"
We got 6" of snow today and I went to start it and nothing happened. When the key was in the run position it would click a little bit from the left hand side. But it wouldn't turn over and no lights come on in the dash.
Any ideas? I haven't checked the fuses or battery yet, (My other Apex started right up so I rode that one)
Thanks!
Thanks!
Yes check fuses and also do a load test to see if the battery has enough juice to turn the engine over. i also have seen battery and trickle chargers give false info.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I know it sounds silly to ask but make sure your kill switch is not pushed down. Your kill switch prevents power from getting to the dash.
It is most likely the battery. Take it to a battery dealer and have it tested. If it tests good look at the connections to make sure they are clean and tight.
If all of that looks good report back and I can walk your through the troubleshooting.
Welcome to TY! Please add your location to your profile.
DEERSNIPER
Thanks I will check that stuff out.
- 8K
