schroon
- Mar 8, 2006
- Schroon lake, NY
- www.pacific-custom.com
What is the reason some people are upgrading their 06 mudflaps to the 07?
kenbar said:I have the 2007 Attak and it also is geting caught most of the time when backing up. If there is loose snow at all it will catch. I will be cutting mine off at the join that is about 2-3 inches from the bottom.
CaptCaper said:kenbar said:I have the 2007 Attak and it also is geting caught most of the time when backing up. If there is loose snow at all it will catch. I will be cutting mine off at the join that is about 2-3 inches from the bottom.
What I did on my 03's was get a piece of nylon webb about 1" and wrap it around the rear bumper bar on one end and on the other end I anchored it to the flap. Down almost to bottom. I did this on both sides and it never gets in the studded track anymore.. I used black webb and ss hardware.
Like the Woodys but with two and it's a lot cheaper...leaves room in the middle for grabbing if stuck and for my dog sled hitch.
ReX said:With it like this you can only back up on hard packed trail (unless you hold the flap up with your left hand).
In deeper snow the 07 flap will still get pulled into the studs very easily when backing up - even when it was pointing outwards by close to 45 degrees (stock).
ReX said:One thing I discovered this season is my sled (hyfax especially) runs cooler with the snow flap bent downwards - close to touching the ground.
A couple of things I like about the new flap: looks and with it being much more rigid you can set it up (bend the mount downwards) so it really captures the snow and keeps the snow dust in the tunnel (better cooling and hyfax lube).
