Pureadrenaline
- Apr 6, 2005
- SW Michigan
- www.myspace.com
FLYBYU said:Put a charger on the battery for a little while. If the battery is low, it'll crank and sometimes pop but won't stay running. Been here a couple of times.
I've got my big one on it and set to engine start. The battery is so dead the second I take the cables off the battery the sled dies.
I'm going to get a new battery and a new set of CR10EK plugs.
FLYBYU
Well that's exactly your problem. The sled won't run off a charger. Put a new battery in it and it will start
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Since you need a new battery you may want to consider upgrading to a YTX20H-BS which has more power and will fit perfectly without using the foam spacers.
Here is a link with more info on the upgraded battery.
http://www.ty4stroke.com/viewtopic.php? ... y&start=30
_________________
_________________
Pureadrenaline
- Apr 6, 2005
- SW Michigan
- www.myspace.com
