NORTHERNAPEX
- Nov 3, 2005
Can someone confirm if this is correct for this kit. All vacuum lines that connect to the throttle bodies together are also T into the sensor that comes with the kit and then connected to the blow off valve on the plenum. One vacuum line that comes from a sensor at the centre of the machine is hooked up to the front of the plenum.
Does anyone have a diagram handy of the vacuum lines and where they connect?
Thanks in Advance.
Thanks in Advance.
