06 SLEDS
Its going to be tight but it will fit. The problem comes in with the hood, the new hood comes off with zet clips and isn't as easy as just lifting it up to cool the turbo after you run it. I have a feeling a after maket hood may be needed. Also the center of the hood is part of the airbox and dosen't come off when you remove the hood piece so a false cover must be made to cover the intercooler. Its going to be a total redesign. Also mapping out for the Fuel injection needs to be done which will be several hundred $$ if done properly. There are several way to trick the system but we can't settle for trickery the fuel system needs to be done right to work all the time in all conditions. This fuel system is sophisticated and must be done right.
It will be a challenge to keep the price down with all these issues.
