jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
Hello guys last upgrade to make is the front shocks so im looking at options i can get a set of used 07 apex gytr clickers for 400 shipped will they work and are they worth it?
thanks jdp
thanks jdp
grader
the apex shocks are not the same length as the rx1, they are shorter.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Thanks did not know that thats why I ask theres always an answer on here. What are my options for an upgrade?
rx1 fern
i put fox floats off a nytro rtx on my rx1 and it made for a better ride .what did you do for rear suspension upgrades.
livinloud
hey rx1 fern i want to put the nytro shocks on my rx1 too but the gytr clickers insted of the fox floats are they the same size and do they fit without any modifications
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
I am running a 151 exert x in the rear.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Any suggestions??????? Need new shocks!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
To the best of my knowdege apex/vector shocks will fit an rx-1. The only difference is the shock length. The apex got shorter shocks and kuckles/spindles which lowered the front end to help reduce the "tippy" feel of the rx-1's. The bulkhead which has the top shock mount is the same between both sleds. The lower a-arm shock mount is also the same between both sleds, so there will be no issue with fit-up.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Thanks its the last thing I want to do to the sled this season! So I wanted to know all my options.
rx1 fern
yes the fox floats bolt right in with no modifacation needed.i like them on my sled and you can lower the air pressure for drag racing also.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Thanks Im looking in to a set of floats now.
