Iceman57
I am looking for first hand experience reports on the performance of the 07 EC Ohlins mono shock. I know the 06 had issues with leaky seals bottoming and wires breaking. I would like to hear if these issues have been resolved with the 07 shock.
I have over 10k hard miles on mine and no issues. Only problem I had was a broken wire on top.
Iceman57
Yummy said:I have over 10k hard miles on mine and no issues. Only problem I had was a broken wire on top.
Is yours a 07 or 06?
rapeape
- Jan 8, 2006
- Brookville, PA
- campkevin.com
My 07 had broken wires which I fixed and put 5 zip-ties to keep it from breaking again. My'06 blew its shock within 500 miles.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
There was an update done to correct the leaking '06 shocks.. Would highly recommend Ohlins..
Shiek
- Jul 21, 2004
- www.sledbitch.com
- 06 apex gt
my 06 shock was leaking at 1800 miles dealer updated to the 07 shock
i put 1200 miles on so far with no issues.
Alatalo
- Jan 11, 2005
The 07 Apex GT has got the updated solenoid wire and the updated piston shaft seal.
Though, the spring and the damping is exactly the same as the 06 Apex GT (=very soft)...
I sent mine out to get revalved and heavier spring after first weekend riding. I'm 225lbs dressed. I have almost 2000 since and no problems at all.
SKIDOZER
I have almost 2000 miles on mine with Pioneer revalve and 6.5 spring no problems at all.
My buddy has same mileage stock spring and shock no problem at all its stiff enough for him stock at 210#
Apex18
Did ALL the 06's get new shocks...or do they have to be blown or leaking. Will yammy still cover it if its not under warrenty you think. Jord
mrance111 said:Yummy said:I have over 10k hard miles on mine and no issues. Only problem I had was a broken wire on top.
2006.
Coondog2707
07. 1100 miles no issues. Rides awesome through any moderate size stuff. Makes it totally disappear, like it aint even there. Has its limitations in bombed out, cratered up trails. Too slow and soft in stock form. Bottoms out frequently. Seems like a progressive rate spring could really improve it. I will be checking my options....
07 attak gt 2100 miles no problems.
SKIDOZER
my 07gt with Pioneer revalve and spring that he recommended for me works great in rough trail and in the big stuff. Hardly bottoms at all .
Well worth the $180.
- 11K
