dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
My dads 07 attack with intense track is going to the mountains (8.000 -10,000ft) with us. He has a ulmer clutch kit previously installed from old owner. Is there any adjustments I need to do to the supertip weights? Does anyone have a spec sheet for high elevation? We live at less than a 1,000 ft elevation.
cacsrx1
Take weight out of the tip and wind the secondary tighter.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
How much weight do I take out? What position on the secondary? I thought i read 6-1 somewhere. What does winding the secondary tigheter do? Is it easy to do?
cacsrx1
You will have to look and see how much is in the tip now and what spring, helix, and degree is in the secondary before anybody can help. Or call Al, its his kit.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Al said put secondary spring In 6-1 position and install a 39 degree helix . He said don't touch the weights which I find weird
cacsrx1
Me too.....dremmick said:Al said put secondary spring In 6-1 position and install a 39 degree helix . He said don't touch the weights which I find weird
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You don't need to touch the weights. Change to a 39 degree helix & set your secondary spring at 6-1 setting and it will work fine. Less helix angle = more RPM which is what you need for the higher elevation to offset the loss in horsepower.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Thanks ulmer found a helix on ebay for cheap!!
- 11K
