Four Bitten
I am suspecting that I have a bad fuel pump. I turn key on and I can hear the fuel pump relay clicking but I don't hear the fuel pump. Can anyone give me any advice on this. Thank's
duste
- Nov 25, 2008
- New Glasgow, N.S. Canada
- 2007 Attak
Hi, are you getting any or multiple codes on the dash??? Is it trying to start or turn over at all?? The more info you can post the more likely somebody here can help you out. There is a port in the electrical section here that says 06 Apex wont start or crank, it was trouble I had last year, this may help you out, it appears to be a common trouble. Good luck
Four Bitten
Sled is turning over and I do notice an engine icon flashing when turning over. Thanks.
T-Bone
check the fuel pump fuse. it is hanging on the side of the battery tray. fuse to the front is the live fuse, one to the back is a spare.
blue er
just went through some gremins with my 06, check the wiring harness that runs down the deltbox on the left side, i had a corroded fuel pump wire and had a couple ground blocks that need cleaning as well.
if your getting a code 43 flashing most likely grounds are the problem
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
also check the fuse that are right next to the battery box i had no power and the 40amp fuse was bad there 2 10amp on each side of it. It's the starter relay
