studdog
07 Attak GT front end feels real stiff (harsh ride) compared to my 06 Attak. I am playing with the GTYR clicker Adjustments. Already softened up front shock springs to Max soft. Am I missing something here? Or are the GT just stiffer in front? I only have 100 miles on the sled and I know it will soften up with miles. Thanks for any ideas. While you at it has anyone softened up the rebound clicker on the rear?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
studdog, shoot a PM to bjniceguy, he has a 2006 Attak that he put the GYT-R (Same shocks as the GT) on the front end and has had a chance to put on quite a few miles. He may be able to help you with adjustments.
NB-NYTRO
I'm not sure about the ATTACK GT... but on my GT I run... 119mm pre-load(if memory serves me right) with compression and 10-11 and rebound at 12. It seems to be a good all round setting.
studdog
Thanks for the replies. Allan, I'll PM bjniceguy as you suggested. Thank you. Anyone esle adjusted GTY-r shocks?
SERPAGS
nb-viper said:I'm not sure about the ATTACK GT... but on my GT I run... 119mm pre-load(if memory serves me right) with compression and 10-11 and rebound at 12. It seems to be a good all round setting.
How do you find the front end react compared to max comp AND rebound?
What conditions do you run on ?
I have the same Attak GT.
I softened my front end 2 clicks "softer"=top & bottom.To me it took most of the feed back out.
Like it better than standered setting.
studdog
If by feedback you mean bumps, I don't want bumps I want the suspension to smooth them out without bottoming. I think I need to put more miles on sled to break in springs and shocks. I suspect it will settle in and then I can adjust to my riding.
NB-NYTRO
SERPAGS said:nb-viper said:I'm not sure about the ATTACK GT... but on my GT I run... 119mm pre-load(if memory serves me right) with compression and 10-11 and rebound at 12. It seems to be a good all round setting.
I've never really rode at the stock settings or any other settings. I bought the sled useds and the guy I bought it from said these settings work good. It rides pretty good. I just need to get my rear dialed in better now.
