07 attak handlebar riser?
olsmann
wi
I have a 07 attak and would like to get a bar riser for it, right now its stock and I just want to gain an inch or 2? I think guys here have done it but I cant seem to find anything when I search TY . Should I just get the power madd block and see if the hardware store has some real long metric bolts ?? Or does anyone here have a better idea ?? I dont really wanna spend a ton buying a whole new set up I just wanna gain 2in at the most. Also does anyone know how tall you can go above stock before you need loner cables?
Contact Richierich and order up a Rox riser. Put a 3.5 on my Attak and it works great! Have to route the wires and cables a little bit, but not a problem.
Just did some better searching and it seems as if the rox is the best ou there. If I go wth the 2 inch will I still need to reroute cables and will the yami pad still fit?
Yes to the wires, and no to the pad. I wear a Tekvest, so the pad was not an issue for me. You could use a full size pad like those used on the older sleds. I took one off my Viper and it did fit, just didn;t like the look very well.
2" Rox Riser (cables are okay)
Also have a bay window--(very warm)
Have two mirrors that look sorta-like antennae (but they work great)
I'm glad to see someone brought up the Mountain riser. This riser I believe is 2 " higher correct? It also looks like you polished it. It will shine up just like chrome. I am wanting a 2" riser and was thinking of the mountain riser also. We also got that same windshield but it is just too warm for me behind it so I put the stock one back on. Gene
i wanted the mt. riser b/c i wanted them a little higher and i wanted to keep the stock look. i love them
lmao, haha "bay window" good one :rofl:
I also bought a 2 inch rox riser. They are really good quality and look great. Perfect height for me. I managed to use the stock yammy pad and the cables were plenty long enough, just have to pull them out a bit. Only took 30 minutes to install. I recomend them. :Rockon:
Same setup for me. I cut the stock pad to fit. Love how you can swing it back for long rides or raise it up for the bumps.
