I have a 07 attak and would like to get a bar riser for it, right now its stock and I just want to gain an inch or 2? I think guys here have done it but I cant seem to find anything when I search TY . Should I just get the power madd block and see if the hardware store has some real long metric bolts ?? Or does anyone here have a better idea ?? I dont really wanna spend a ton buying a whole new set up I just wanna gain 2in at the most. Also does anyone know how tall you can go above stock before you need loner cables?
- Jun 28, 2004
- Clinton, Wi.
Contact Richierich and order up a Rox riser. Put a 3.5 on my Attak and it works great! Have to route the wires and cables a little bit, but not a problem.
Just did some better searching and it seems as if the rox is the best ou there. If I go wth the 2 inch will I still need to reroute cables and will the yami pad still fit?
- Jun 28, 2004
- Clinton, Wi.
Yes to the wires, and no to the pad. I wear a Tekvest, so the pad was not an issue for me. You could use a full size pad like those used on the older sleds. I took one off my Viper and it did fit, just didn;t like the look very well.
newfieattak
got a powermad pivot and 6 inch riser on mine,no cable mods, still got the bar pad
timebomb
put the apex mt. riser on my attak. fit fine, cables were plenty long enough
tryanATTAK
I'm glad to see someone brought up the Mountain riser. This riser I believe is 2 " higher correct? It also looks like you polished it. It will shine up just like chrome. I am wanting a 2" riser and was thinking of the mountain riser also. We also got that same windshield but it is just too warm for me behind it so I put the stock one back on. Gene
timebomb
tryanATTAK said:I'm glad to see someone brought up the Mountain riser. This riser I believe is 2 " higher correct? It also looks like you polished it. It will shine up just like chrome. I am wanting a 2" riser and was thinking of the mountain riser also. We also got that same windshield but it is just too warm for me behind it so I put the stock one back on. Gene
i wanted the mt. riser b/c i wanted them a little higher and i wanted to keep the stock look. i love them
timebomb
tcona-AGT said:2" Rox Riser (cables are okay)
Also have a bay window--(very warm)
Have two mirrors that look sorta-like antennae (but they work great)
lmao, haha "bay window" good one
Apex18
I also bought a 2 inch rox riser. They are really good quality and look great. Perfect height for me. I managed to use the stock yammy pad and the cables were plenty long enough, just have to pull them out a bit. Only took 30 minutes to install. I recomend them.
Mikecam
