Has anyone heard if the dealer can remap the 06 Apex with the mapping from the 07 model. From looking around various forums it sounds like the 07 has a snappier feel to it.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
2006 & 2007 fuel mapping is identical. It was internet hearsay about the fuel mapping changing.
slymax
Something is different. Ride an 06 and an 07 back to back. Same gearing/clutching. Way snappier feel ??? About to run two turbos back to back, 06 and 07, both with 07 MCX kits and identical clutching set ups. Will report once we have a few miles on 07 for break-in.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Swap ECU from sled to sled. Just riding the two sleds side by side isn't a good enough comparison. Leave the sled the same and simply swap ECU's. A recently dynoed 07 only made 147 hp where most 06's on that dyno were 149-151.
powderlites
ECU
2006 Apex mountain has different ECU 2007 Apex has same as short track 2006.
Mapping on 2007 same as 2006 short track and turbo guys from what I have heard need more fuel on top end Must be a mistake in mapping on mountain sleds cause at high alitude 2007 flys compared to 2006 stock to stock
http://www.powderlites,com/turbokits.html
How would I get my 06 to perfrom like the 07,at high altitudes, I ride in high altitudes upto 11,000 feet.
n2oiroc
i heard about an altitude compensator update for 06's running over 6,000 ft. it was on one of the 2 ty forums.
ski-bum
n2oiroc said:i heard about an altitude compensator update for 06's running over 6,000 ft. it was on one of the 2 ty forums.
I hadn't heard about this, anyone else have more info?
My local dealer is snowmobile ignorant which is why I purchased my Apex from a different dealer. They didn't even know about 0-30 oil until I asked them to order some. So I need as much info about this high altitude setup as I can get.
Yakuza
ski-bum said:n2oiroc said:i heard about an altitude compensator update for 06's running over 6,000 ft. it was on one of the 2 ty forums.
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
Yakuza
Spoke to Yamaha Cypress today. There are two modifications for the High Altitude Compensator, 93-ACL and 93-ACM. you have to give the dealer your VIN# and altitude you ride and they'll fix/adjust it.
I will get a hold of the dealer today. I took the sled out Wed. and noticed that I really lose power as I go up in altitude I started out on top (10 to 11k) and as I dropped down about 1000 to 1500 ft the sled felt like it was running way better It was even getting about 1000 more rpms on the tach.
Tgator
Yes there is a alltitude compensation program but it is for your clutching and jetting on carb. models not to change fuel mapping on fuelies the mountain sleds come set for 8000-10000 and if you run in lower elevation they will pay to set the clutchs right the first time from the dealer
REXX
- Jan 5, 2007
Yep. At lower elevations we clutch the same as the Warrior or Attack. With stock weights I can blip to 11200 rpm between 1/4 and 1/2 throttle. I can catwalk down the backside of hills all day long..
vectorboy
I had a 07 and a 06 out at the same time and i can honestly say i didn't feel a difference between mine and the 07. If there was a difference i'm sure i would have noticed. Sorry.
