spike5om
I don't know if its leaning out or the rev limiter, I have an ullmer clutch kit, free ride track, air box pods, and hauck dual exhaust that i just installed while testing it I then notice this problem? Any Ideas???
Zakre
what rpm are you seeing? I think the limiter is 12500 on the phazer, you want however like 11200-11500 to be full out.
spike5om
i did see over the 12k not exactly sure how high, was just a quick test run got to cold with out a helmet.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
Is it acting like its on 'limp mode' ?
spike5om
I never had the issue before the exhaust know i do? I suppose its breathing better and thats putting me over the top? What would be a quick easy solution to bringing the rpm's down sense i already have a clutch kit?
spike5om
It's fine until i really crank on it, then it cuts out pretty good then if i am still on it hard goes cuts a little and so on and so forth.
You need to add wieght to your primary.You want to see about 11500 rpm.When I was messing with exhausts I was constantly having to change the clutching.Thats good because it shows you are making power but it is a bit of work.
xt_gt
did you adjust the secondary at all? may be something as simple as moving the spring.
there is a write up in another post thats shows the degrees for the spring. or just give ulmer a shout.
otherwise it's more weight on the primary like cannon said.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
What are your RPMS at sounds like the rev Limiter
spike5om
I have seen over 12000 rpm's, how high after that i don't know for sure. I haven't messed with the secondary at all, just a clutch kit on the primary. Anyone have a link to the post about the degree of the secondary?
I think I must be hitting the rev limiter then, just want to make sure I can still ride it with out hurting it until i get the problem taken care of?
yam177
- Aug 14, 2008
- Shoreview MN
Your in mn if u want to come to my test track we can tune it pretty quickly for u
spike5om
Well thanks for the offer, might take ya up on it if I cant do it my self, but I should be able too. I can't remember if ulmer has you mess with the secondary at all when you get there clutch kit or not, its been a while sense I installed and can't remember for sure. Was wondering if I should mess with that first or the rivets on the primary? Need some suggestions!
You will end up doing both or just add rivets.
RayKnobs
- Feb 24, 2010
- Rochester, NY
- 315er.net
Ulmers instructions are on the website. I don't recall any changes to the 2ndary
spike5om
When I ad more rivets, where do i get these other rivets, is there a specific size I need? How many should i get/ put in?
- 8K
