Nice Rumble
I installed the '07 wiring harness on my '06 bars. Warmers now work like a charm. I now have the yellow warning light. Is that because I installed the new harness or something else? The light was on initially because I plugged in the harness wrong and had no heat. I got it sorted out, got great heat and no light. Now I see the light again. Hmmm?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Low fuel? This seems to be the popular warning. lol
When ever that yellow light is in, there is a symbol that displays in the L.E.D. screen. Match up that symbol to one in the list from the link below. That's where you should start at. Can't fix the problem unless you know what's broken.
http://www.ty4stroke.com/viewtopic.php?t=36172
Hope this helps ya out.
-Vince
-Vince
Nice Rumble
I suspect your right about the fuel as it wasn't on before and I noticed I was low on fuel with only 1 bar showing. I'll check the icon. Thanks.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Nice Rumble said:I suspect your right about the fuel as it wasn't on before and I noticed I was low on fuel with only 1 bar showing. I'll check the icon. Thanks.
Sounds like it then. If I remember correctly, that is when the light comes on and you have like 3 or 4 gallons left.
