Rove44
i have an 07 apex. on friday while riding my temp light and warning light along with the little temp and engine icons came on. My tach does not work and speedo shows zero ,hand and thumb warmer bars not working but they are putting out heat.. also flashing err1 and err2 sled runs fine went back to normal a few times now just stays that way. unhooked battery reconnected no luck . Sorry about the long post, Any help is appreciated.
Try this link. It has to do with the ground blocks. Could be the problem you are that you are expierencing http://www.ty4stroke.com/viewtopic.php?t=83994&start=0
Rove44
Steiner, checked the link you posted and i dont seem to be experiencing those same problems. I went thru all wires and connections and they appear dry and clean. thanks for the input i appreciate it.
Rove44
Found out from my dealer that the speedo cluster is bad. only $700 for a new one
get a used one!
snife
guage
We had one in our dealership do something similar to this. We took the guage apart and there was light corosion on the solder points of the printed circuit board. We cleaned the circuit board really good with alcohal and Q tips and it has worked fine ever since.
