07 Idlers wheels delaminating? Please help!
On the weekend I was checking my back wheels...and guess what...all the bearing were jammed! Only the extra fourth wheel was OK. And also the bearings can't be changed on the outside wheels.@#%$@#$@#$
That it!
I'm thru with Yamaha wheels. I orderred all Kimpex wheels, including the direct replacement for the rear inside idlers 116-96S.
Will let you know how they goes.
Good day.
Well, did 750 miles on the Kimpex this weekend...All 6 outside wheels are OK. BUT the two inside back wheels (116-96S) lasted only about 300 miles. I really don't think the product is at fault here. I believe there too more pressure from the Mono suspension. For now I'm back using all plastic Yamaha wheels for the inside back.
Anyone had the same experience with those 116-96S wheels?
over 2000 mi. on my attak with the skidoo wheels, zero wear, what size are the wheels did you go with the 130mm or 135mm ones?the kimpex equal to the doo wheels are the kx411667 w/ the 6205 bearings
Yes the Kimpex are with the 6205.
What are you using for the inside back wheels?
yes, they are 135mm.
If you run them at the back, it mean you had to machine the wheel mount a bit....right?
Can someone tell me if the back inside wheels from 08 model are the same as the 07?
The bearings are shut on mine and they are the solid plastic one with non removable bearing. I did try others but they all delaminated! The only one that resisted are the 100% plastic wheels. Anyone with the same problem?
I put Polaris wheels on my 06 Attak after my Yamaha wheels exploded after 72 miles.
I currently have 2645 miles on the sled........and no problems with the Polaris wheels.
I only needed a longer bolt........and they hooked right up!
Good Luck!
GE ;)!
I put the spoked Yamaha wheels from the Yamaha book. They are still great and you can replace the bearings
Yummy....How is Rouyn? You guys riding yet?
went through 20 WHEELS and no im not kidding 2400 miles voiced my concerns to Yamaha Canada and would not back up claims at all the rubber just falls off the wheel no chunking or anything just falls off.
