07 phazer over heat
jeff m
has anybody with an 07 phazer had water pump problems. the engine light comes on with excessive hard trail ridding. just started last ride in good trail conditions.
Just a hunch, check that the fan is pulling air front to back, if it's running at all. Heat exchanger icing is sometimes an issue.
Moved it to the Phazer section for you.
x2 with what mooseman said.
I added a FrogzSkin vent to the lower part of rad cover, havent seen temp light since.
I also had an insanely dirty and damaged secondary clutch that was adding to the heat problems.
