I believe my o7 RTX is running a 22 upper gear? All of you guys that are testing seem to be going to a 23 from a 24 is this correct? First is the clutch weighting/spring in my RTX any different than what the other Apexs are running and second is the 23 the optimal gear? would I be better off to go up to the 23 or stay with 22 and turn clutch for shift out with an aggressive clutching setup? I would like to get the most of my 800 foot runs.
