drag123
- Feb 16, 2009
- Ottawa
- 08 fx nytro
I have a problem with my 08 fx nytro surging at around 108 km hour and will not accelarate past 9400 rpm. It feels like its runing out of fuel or something any help would be appreciated.
kyleg
9400 I think is where the rev limiter kicks in. Sounds like a clutch problem.
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
Yes you are bouncing off the rev limiter, you need to add weight to the clutch arms to get the rpms down to 8800-8950
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
If you are hitting the rev limiter at 108 Km/h, I would agree that you have a serious clutch issue. This goes beyond adding weight to the arms. Are you running a clutch kit? Have you changed anything lately?
Are you familiar with clutching or do you have a buddy that is.
How is the belt, and how high does it sit in the secondary clutch?
How dirty are your clutches (never use any products to clean the faces, Only scuff with scotchbrite pads).
With the track elevated can you rotate it easily by hand?
Give some more info and people here will be glad to help.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Is your skid plate still there under the engine? Sounds like you are getting snow on your clutches and belt is slipping.
R00STER
- Mar 3, 2013
- Timmins, Ontario
Good point, I for got to mention that as well. Easy to forget that one when you are running the mountain tech plate.Is your skid plate still there under the engine? Sounds like you are getting snow on your clutches and belt is slipping.
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
ware where you when you got your snowmolbile so full of snow
