sled runs great and rides great but when i come into some corners the ski wants to lift and sometime it doesnt and i have changed the air pressure up front and put more pressure on the shock in the skid. anyone got any helpers? thanks!
Set your floats to 50 PSI. Tighten the front limiter strap 1 hole and loosen the center shock spring as much as you can. A 13MM sway bar and a set of pilot skis would make it perfect.
