blazerhazer
I picked up an 09 nytro with a homemade turbo setup. It's put together pretty well and was running the power commander V. The belt snapped and hit the PCV and it's not working anymore. Since dynojet discontinued their line, I found a PC3 on marketplace for it. The problem is it didn't come with a basemap. I found the thread with the maps, but I can't open the .mpp files. I tried everything from converting the file to different file readers.
Any leads to a base map that will open? Even if it's for stock. PC3 software uses .djm or I can import a .map file
At this point even something I can open up in ms project or excel and type in everything one by one would be useful.
I'd love to run the PCV with autotune, but haven't had any luck finding one. I was told the sled is running 8psi of boost.
