Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Who has accurate measurements for the stock skid mounts on the new Nytro XTX with the 144 skid. I assume that these measurements will be relative to the center of the axle with 8-tooth drivers.
I am putting it in a 2003 Viper Mtn chassis, so any input on ride height might be helpful also. I will likely create a triangle template (Driveshaft - Front - Rear) and rotate it on the driveshaft until the track will be flat on the ground. This will determine how high or low my mount locations will be.
I am expecting to have to make brackets at least for the rear.
Anybody got any input?
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
I am not finding these measurements. Can someone who has received their XTX measure it for me?
Can anyone get this info from Yamaha?
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The MTX may be the same. I think the difference in the skids is the length behind the rear arm. Too bad for you mine is in the trailer still.
I haven't looked very close in the pictures, but that's what my impression was.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Can anyone help?
Deadman
most of us don't have our XTX's yet!
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Now that more of you have your XTX's, can someone with the skid out measure the mount locations for me?
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
??? XTX Skid Mount Measurements ???
Ok, somebody has to have the measurements by now . . .
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Anybody got measurements?
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Anybody out there?
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
I have the following measurements
Anybody got any advice?
This measurement is without allowing any difference for going from 9-tooth drivers on the donor sled (2009 Nytro XTX) to 8-tooth extros on the Viper. But that is only about 1/2 inch right?
Can someone Verify, Refute or Add to my measurements please ?
- Axle center to front mount center 8.53 inches (21.7 cm) ---- compared to 21.35 cm (your measurement)
Axle center to rear mount center 37.09 inches (94.2 cm) ---- compared to 94.35 cm (your measurement)
Front mount center to rear mount center 28.5 inches (72.4 cm)
- Tunnel brace (protector) to front mount center 5.125 inches (13 cm)
Tunnel brace (protector) to rear mount center 9 inches (22.7 cm)
Tunnel brace (protector) to axle center ??????? I don't have this
snownutz
If you have a donor sled why don't you make a template off it. Just a thought.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
I only had 5 minutes with the donor sled before I had to leave. I just didn't get good enough measurements. The drive axle was out, so I had to do some fancy figuring and it took all my time.
Ding
- Dec 21, 2004
- Howell, MI
- Black & Blue
Update: For any watching . . .
The measurement is indeed 28.8125 (28 13/16) inches CTC of the 2 mount points. I was finally able to verify this myself.
Thanks for playing.
Thanks for playing.
