chadman
I was riding my sons 09 phazer gt and the warning light started flashing and the fuel icon with all the fuel bars were flashing also and we had filled up with gas 10 miles before this happened. Any ideas?
That means either the sender is no good or an open or short in that circuit.
chadman
any idea where to start, is this a common problem? Thank you
First of all make sure the plug hasn't came undone.any idea where to start, is this a common problem? Thank you
Sometimes they develop bad spots inside the sender. The guage may work when the tank is right full for example, but not at other levels.
Fill the tank up and see if it acts normal again.
If you locate the plug, you could unplug it and use something to close the circuit going into the harness. That will help to narrow the problem down.
chadman
Thanks, I will try that.
RobX-1
- Coldwater, OH
