dmelectrician
My brother-in-law has a 2009 phazer RTX.. When he starts the machine and the engine is cold it starts fine. After the machine has been run for a while and he takes a break the machine will start but he needs to tap the throttle and then its fine.. He asked the dealer and they said it is normal for 4 strokes.. Is this true or is there something else.. Thanks in advance..
When you say tap is that opening the throttle a bit? Sometimes mine i open the throttle a bit. I think if you idle it a few seconds before shutting the engine off after a hard run it might start easier for him
Otter
Otter
fraolib
mine does it also. after its warm when u start it it will run for a brief second than shut off. i just keep crankin it over. it starts after like 3 more cranks
dmelectrician
yea just open it a little.. Ill have him try to idle it for a few seconds before he shuts down too.. Thanks for the responses guys..
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
take a look at the idle speed my 09rtx had trouble starting after it was good and warm. After it would start it was idling at 1500 i adjusted it and works good as new
