david galloway
phazer starts fine when cold but has a little trouble starting once has warmed up. i need to crack the throttle abit while cranking. any suggestions?
Check you warm idle should be around 1700 - 1800 RPM.
david galloway
-warm idle is 1700-1800.
CJW
- Oct 7, 2007
- Ypsi,Mi
- www.taylorjetboats.net
I am having issues with the throttle position sensor on the wifes 07 Mtn Lite. That might be something you want to look into.
