09 xtx lower ball joints
drunkenrich
Thomaston, CT
Hey guys
Did the a arm bushing last year with the copper ones and wanted to see how they holded up so i put the front end on the jack tonight, bushings are good but noticed a good amount of play in my lower ball joints. Was 09 nytros covered in the recall of these? If so, is it to late to bring it to the dealer. If it is, then what kit do you guys recommend?
If you're hanging onto the sled it's a perfect time to replace the garbage OEM front end. Mountaintech 43" Kit!!
Haha don't forget shock spherical joint mod too.....It is a very good price for that product. $800 is cheap
If your replacing the balljoints, replace with stock units. Not sure about the recall, have to check with your dealer on that one. Have you checked your spindle bushings, that is another area for wear. UP bushman kits are prob the best for replacement.
Yes go with stockers, they are pressed into the arm and held with a c-clip. Be easier with the arms off the sled but can do it on the sled. No problem
There is a actual tool to press them in, ur dealer might have it. But yes a vice and socket will work just fine.
NCI used to make a lower oilite kit for the bottom ball joints not sure if they still do.
