sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Port Yamaha or yamahapart.com
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I found these but is a Canadian retailer. Price seems reasonable but I have no idea of quality/reliability.
http://www.ty4stroke.com/threads/aftermarket-balljoint-for-phazers-nytros-vls-and-mps.128008/
drunkenrich
How much are those each mooseman?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
According to Winners Circle's catalog, $30.58 CAD each. That's $28.06 USD after the exchange for the Canadian pesos.
drunkenrich
these will fit an 09? it says 08 only
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Only way to know is to check in the Yamaha microfiche to see if it changed from 08 to 09 or buy them and try them.
drunkenrich
They are the same part number from 08 to 09 on oem yamaha fiche. I will try them, thanks
drunkenrich
just put my order in online through their website, tried both 1800 numbers but both were out of order, looks like this is a gamble, we'll see what happens
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I just tried it and it rang, they were just closed for the day. Probably it's a 1-800 that works only in Canada. I'm sure their direct number would work for you. I'm confident that it's all legit.
Would appreciate a report back when you get them with pictures. There is a way to know if they are the same as Yamaha's.
drunkenrich
mooseman
They processed my order, got an email. Came out to roughly $72 American, not bad. I will let you know when I get them.
drunkenrich
Found this for torque specs, is Nm foot pounds? What the hell is Nm?
upper a-arm to subframe: 45Nm
lower a-arm to subframe: 65NM
Shocks upper and lower: 45Nm
lower a-arm ball joint to spindle: 65Nm
Upper a-arm to spindle: 45Nm
nm= newton meters , or in other words foot pounds in metric. most newer torque wrench are marked for both but the values can be converted over if nessasary.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Just put those numbers into Google for a conversion. For example:
45nm in ft lbs
Works for any conversion.
45nm in ft lbs
drunkenrich
Thank you
drunkenrich
Mooseman, i got the ball joints in today, look good. Did you want specific pictures?
- 7K
