adirondac blue
Can I run this gas straight and what boost level is it safe for, 8, 10, or 15.Stock motor with cpr turbo.
octane
your stock motor is 11.8 : 1 compression
so running 12 lbs boost will require 100 octane fuel @ sea level.
and bring you boost compression to 11.8:1
13.5 lbs @ 3000 Ft
15 lbs @ 6000 Ft
Remember that these numbers are @ wide open throttle.
Prolly 10lbs for normal use.
U can always mix with pump premium to get lower levels
13.5 lbs @ 3000 Ft
15 lbs @ 6000 Ft
Turbo Tim
I run 100 percent 100 LL avgas in both of my turbo sleds ......better safe than sorry .........9psi w/ the Simons cpr turbo and 11 psi with the bender turbo .......both have the 0.54 headgasket.
Buckeye
- Lakes Region, NH
I ran Sunoco 100 race gas and 12#'s with .054 head gasket last year on my McXpress front mount with zero problems.
