legend
how big of stud can you run thanks
Rick27
With or without the fatboy spring? LOL!!!
legend
it is a se
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
I have an 2011 SE.
I am running 1.325's Woody's Megabytes. No Issues so far. 1200 km on it.
Track must be run to spec. Loose you will have an issue.
Yamaha has a service bulletin out recommending 20 mm spacers on the tunnel protector supports.
There is a thread here on things you can do to protect yourself .
boostedapexse
- Dec 31, 2010
I have 1.450 grandmaster no issues the only problem they have is they need the factory tunnel protection braced properly, I put a piece of 1" aluminum square stock in right by the factory bracket and riveted it there and it takes care of the problem.
legend
ihave 14 50 mega bites.if shimed will they work thanks
