ManhattanMike
- Jan 29, 2008
- Mokena, IL
- 2020 Sidewinder SRX LE, 2018 Snoscoot
I want to go to a 136" track under my apex er, do I have to do an entire suspension swap or can I extend the 121?
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
you can get 136 extensions
rindtj
When you want to do this by? I would be interested in trading my 136 skid for a 121. Keeping shocks and wheels. Trade everything else.
sherlock29
just remember rear arms in the 136 and 121 are different... 121 have upper wheels on them... 136 has rear cross shaft with wheels. but i'm sure you knew already ;-)
ManhattanMike
- Jan 29, 2008
- Mokena, IL
So if I was to just swap suspensions would it bolt right in or would I have to modify anything besides the tunnel extension?
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
You need the rear idler wheel support bracket rear idler wheels with cross shaft (both support the track behind the rear suspension mount). Tunnel extension, coolant hoses and covers. Also need the rear suspension arms. Go to one of the Yamaha parts micro fiche and compare the parts drawing and numbers. If you are not pic'ed then you will not need cooler protection.
